Jenkins54
- 2
- 1
1) I couldn't find a definitive answer, but what I'd like to find out is if when viewing the RTSP streams from the NVR on "rtsp://ip-address/Streaming/channels/101" whether this produces the main stream directly from the camera, or whether it is re-encoding it at the NVR level and then producing it? I would rather configure the settings on the camera level first then just use the NVR for the POE, recording, and viewing only.
2) In relation to Q1, do the settings on the NVR under "Device Parameter" > "Video Parameter", change the camera stream settings directly, or again is this at the NVR level only?
