I'm having a slight problem with my Hilook ip/network camera and was wondering if anyone can help.
So my Hikvision Nvr configuration menu won't pick up the ip camera when it's connected to my POE switch but when I connect it directly to my home ISP router the Hikvision NVR picks it up fine when you press refresh.
The wierd thing is when the ip camera is connected to the POE the Hikvision SADPTool picks it up fine and I was able to connect it to the Hik-Connect app and it was running all fine.
Any ideas on how I can gain access to the camera via the poe switch through the Hikvision NVR as I would ideally like to add a couple ip cameras to my current 4 ch nvr setup.
Thank you very much for any help.
Regards
T
Regards
T
