Using my Hik-Connect app, I can stream 7 out of my 8 cameras when using wifi on the same network as the cameras. If I use mobile data or I’m away on a different wifi network, I can stream all 8 cameras.
I’ve tried changing the IP address of the camera but that hasn’t changed the issue. Im assuming something is clashing with that one camera? (The firmware is up to date and the settings are the same across all the cameras).
Thank you
Thank you
