PoE Switch for 3 cameras
Sam1980
I'm in the process of setting up my first CCTV system as follows:
Hikvision DS-7604 NVR
Hilook IPC T250H 5MP turret cameras x3
Hilook NS-0105P-35 4 port 100 Mbps Poe Switch
I need to use an existing hole in my wall that will only accommodate 1 wire - hence the need for a switch. Both the switch and the NVR will connect directly to my router.
The switch will be protected by an outdoor enclosure.
Each camera will be <20-30m from the switch via cat5e cables.
I believe the total wattage required as per camera specs is 26W max
I believe the total bandwidth required will be around 28Mbps
Does this sound like it'll work? Is my working correct?
Yes, that all sounds fine :)
great! thank you
just one other quick question, is there anything like an outdoor rated/weatherproof switch you could recommend so I don't need to use an enclosure?
You may be able to find something, but it will be 'industrial' and at such a price premium that undoubtedly an enclosure will be more cost-effective.
