Hi all,
I am quite new to all this and want to expand my knowledge with some home projects.
I have a talk talk router. I am planning to connect the router to one of the 4 ports on a Unifi switch flex mini, which will be next to each other. The switch will be powered by a USB C wall socket.
I have a Ethernet port on the wall next to my router which runs outside of the house up to a bedroom. I will plug an Ethernet out of the POE switch into the port downstairs which will give me internet to the port in the bedroom upstairs.
So basically at this point, the downstairs switch is giving internet and POE to a Ethernet port in a bedroom.
I then plan to add another POE switch (will also be powered by wall socket) to this port upstairs and run 1 cat 6 to another POE switch in the loft to power 4 Hikvision IP cameras. This POE will not be hard wired and hoping it will be powered by POE?
Can anyone advise if this will work please? I am thinking that due to the Poe switches being powered that POE cameras will power up with no issues?
Is there a limit of daisy chaining POE switches for power? For example could the switch in the loft that is powered by POE also power another switch in a different location?
Many thanks
Jack
Many thanks
Jack
