Powering a Ubiquiti POE dome camera from 24v batteries?
jjsatrech
Hi all,
I'm settling up remote CCTV cameras and I have a problem to supply my Ubiquiti dome with 24v POE.
I can't find a POE switch that can be supplied with my 24v batteries.
When I tried to power the Ubiquiti using the #4 and 5 of the RJ45 I blew my network switch.
Did I use the wrong wires on the RJ 45 or is it not possible to do it that way?
I will really appreciate some advice.
Cheers
JJ
The POE camera will expect the network connection / POE supply to be in a very particular format (the IEEE802.3a_ Standard).
You'll need to source either a specialist POE switch that can be powered by your 24V batteries and produce POE to the standard, such as this example:
Or, use an inverter with your batteries to develop mains voltage and use a standard mains-powered POE switch.
