Hi all,
I have bought a fairly new built house that came with 8 Hikvision cameras in the outer areas and also with Hikvision NVR.
The model is: https://www.hikvision.com/en/products/I ... 2345FWD-I/
I suppose they are good cameras but I find it wrong running the NVR as I also have a Synology NAS running.
What do you think about kicking out the Hikvision NVR and hooking all the cameras on the Synology Surveillance Station?
Is that a dumb idea because the Hikvision NVR and its iOS App etc is the NICER solution?
I will anyway tuck away the Hikvision gear in a separate VLAN so it doesn't phone home so much
What do you think?
/T
P.S.: Unfortunately we are only moving in 2 weeks, so I can not try out much. The other problem is, that I don't have the access to the NVR as the pre-owner thinks he doesn't remember it. So in case he can not recover it. I am forced to factory reset the cameras anyway, then I can as well just install the Synology.
What do you think?
/T
