Hi All,
I'm new to this forum, hoping someone can advise.
I currently have a ZOSI ZR04RN10 4 channel NVR system. This has 4 PoE 1080P cameras.
I wired the system using the supplied ethernet cable, it is 2pr twisted rather than standard 4 pair twisted, and replaced the 1TB drive with a 3TB drive.
From the start it has crashed regularly without warning.
I wish to replace the system as it is becoming increasing unreliable.
1) If I choose another system can I use the existing wiring as is, or does it need to be changed to standard ethernet 4pr twisted?
2) Can I use the existing ONVIF cameras, are they compatible with other NVR systems?
3) Are there any recommendations for a reliable 4 channel NVR 1080p or better?
I am in the UK, I can spend around £500-900.
I am assuming they all have similar features including remote access via a smart app?
Needless to say I would prefer to retain the original wiring if possible as I have put considerable effort in running the wires through the loft and into stud walls and I am not getting any younger.
David
David
