hi there, im john and new to the forum.
ive had 4 x ds-2cd2742 cameras for a number of years into a poe Ethernet swithch just using the internal memory cards inside the cameras.
Ive just upgraded to a ds-7608 nvr from use-ip, got it all set up and working as far as using ivms 4500 on a smartphone but it will only work over my wifi, I cant get it to connect remotely over 4G. I am getting a "connection failed" message which im sure some of you will have possibly come across?
Years ago I had to open certain ports on the router (bt) and since then ive ugraded router several times and never had to forward ports on subsequent occasions. Ive added the nvr to ivms 4500 using the ip/domain settings and ipv4 address but im struggling to add the nvr using hik-connect domain, when I try to input device domain it says "no online device added" .
I have checked the enable platform access box and selected the only option of hik-connect , I have a verification code and qr code but im stuck...any help appreciated .
john
john
