Rtsp for channel zero Ds-7608NI-I2 /8P?
rajiv.dey.se
Hi all,
I have hikvision nvr model Ds-7608NI-I2 /8P
I have enabled rtsp and channel zero encoding
Also I can view individuals camera through nvr using vlc folowing pattern of network stream.
rtsp://ipadress:portnumber/streaming/channels/101
I could view other camera too by changing the channel number.
But i can't view chanel zero which is a channel containing all camera feed
I tried different channel number for channel like
000
001
Nothing worked what would be right channel number to view channel zero as rtsp
N.B:- apologizes I tried lot to edit the quoted text not use emoji but when I give colon the emoji comes. Feel free to edit the post
Hi all,
000
001
There is no url for Channel Zero - it’s not available that way
There is channel zero. Please check hikconnect app there is option to hide/display channel zero.
Also see this forum it seems it's a bug. As to view channel zero we need hdmi monitor. Which I do not have.
Yes there is Channel Zero but you cannot view it using VLC (via url)
Ok.. I am bought a dummy hdmi plug. I will post if nvr graphics card needs activation to watch channel zero using vlc. I am also trying to borrow a monitor from my friend. I will post here the result.
According to some of my previous notes I got this working in the past using this RTSP URL:
/Streaming/Channels/01
I can't remember which of my NVRs this was on and I can't try it myself right now but give that a go.
Channel zero works with rtsp and channel is 1 but we need tinker live view settings to select right screen also I attached hdmi monitor not sure if that activate the graphics card. But after disconnection of hdmi monitor channel zero still accessible
