oceanblues
- 2
- 1
Hello friends,
I have a hikvision camera DS-2CD2412F-I , I somehow cannot reset it by the push button. But this is not just for this one. I have 7 of them and 3 of them won't be reset with the reset button. Even when I try to reset them, they are not "inactive" on SADP. They have the default password etc. but they stay active on SADP. So I don't get a camera that is reset to factory settings as a new one and is deactivated yet.
Furthermore my main concern is about one camera, that does not come up in SADP. I have traced its IP address... It's mac address somehow doesn't appear on IP following programs. That probably is the main cause that it does not appear on SADP. Its ip address is 192.0.0.64 I changed my routers ip address to 192.0.0.1 and reached the camera I tried to change the IP address. But the camera doesn't seem to respond as normal. It only collects my orders when I try several times. What do you think? What should I do? How should I proceed with the camera? I can change the Ip address and can connect it to my Network. But DHCP doesn't seem to operate correctly. When I enable the DHCP, it doesn't take the proper IP address. But when I give it a fixed IP adreess, I can connect it to my network. But still it is not recognized by SADP or Hik Connect.
Thank you for your advices in advance.
