Hello All,
New to IP/NVR cctv. Previously used consumer based WiFi cameras.
My current systems includes: 1 x DS-7604NXI-K1/4P (Firmware: v4.74.000 build 230213) with 3tb Seagate Ironwolf HDD and 4 x DS-2CD2387G2-LU (Firmware: v5.7.3 build 220112).
I have several weird and wonderful questions about my systems setup which I hope someone could help me with.
Q1. In the Hik-Connect app whenever I get a notification and click playback, I've noticed that all videos are 2 minutes and 10 seconds in length. After looking at both the NVR and Camera settings the Pre record is set to 5 seconds which appears to be working and Post record set to 30 seconds (Would like it to be lower but minimum is 30). Is there a reason the videos are so long when all of the event has ended after 30 seconds? Is there a way to change this?
Q2. When playing back some videos, I've noticed that sometimes it will stutter/lag. What I mean is the pre-record takes place, then the event but the video freezes after maybe 10 seconds before resuming with the counter in the top left having moved on say 7 seconds in length. My cameras are setup to 15FPS Medium with varying bit rates which I didn't actually set. Any easy way to fix this issue?
Q3. All of my lights have supplemental lighting, is there a way to turn the light on when an event is triggered? Specifically I'd like it to trigger the light when an event is captured between set times (No point triggering the light in broad daylight!). I've checked both the NVR and Cameras but there is no option in the Linkage Settings to trigger the supplemental lighting.
Q4. What is the recommended broadband speeds for a system like mine? It's currently installed in our loft and is receiving internet via powerline adaptor that's providing a download speed of 32Mbps and Upload speeds of 12Mbps. Is this sufficient or should I look into getting better speeds for the NVR?
Any help on any of the questions
Best Mattyc491
Best Mattyc491
