Hi Guy's,
We had a NVR DS-7608NI-K2/8P installed yesterday along with 8 DS-2CD2183G0-1 cameras. NVR Firmware: V4.30.011
We were able to view all cameras on the main screen at 640X480 then select Switch to Sub-stream and select 8MP, this appeared to be the default state, no settings were changed.
When we came in this morning, all the camera inputs were displaying NO RESOURCE. If i then selected Switch to Sub-stream an error appeared "Stream Policy Switch Failed" the message would vanish and there would be no change.
I have noticed that instead of the default 640x480 view, all the inputs were on 8MP. The only way i've been able to view the cameras is to manually change their main resolution with Record>Parameter down to 1920x1080. The options for Sub-stream are still there and appear to be ok.
