Synology NVRs
Status
Not open for further replies.
Synology NVRs and VisualStation
NVR1218, DVA1622, DVA3221, VS360HD
NVR's (Network Video Recorders) are a neccessary part of any security setup.
They work to store, playback and support the live feed of security footage from connected IP Cameras, and with Synology, can offer even more.
Offering a range of Network Video Recording solutions, from their energy efficient NVR1218, and compact VS360HD, to their deep learning, AI powered DVA series, Synology's selection of NVRs were designed to appeal to a range of different users and applications.
At Use-IP you can now choose from these four Synology NVRs and decide which is best suited for your needs.
NVR1218
The Synology NVR1218 is a 2-Bay (Reaching a max. of 7 bays, with an Expansion unit) Network Video Recorder, able to support a max. of 12 IP camera channels.
Its design is also fit for a PC-less experiance (only needing to be connected to a monitor) and can be accessed remotely, via Synology's Surveillance Station, or, DS cam mobile application (allowing for Live view, playback, adjustments, and notifications, on a mobile device).
  • Embedded NVR SoC
  • 1 GB DDR3 System Memory
  • Drive Type - 3.5" SATA HDD
  • 1080p 60Hz Video Resolution
  • HDMI x 1 Video Output
  • 3 Year Warranty (Extendable to 5 year coverage)
Deep Learning NVR (DVA) Series
The Deep Learning NVR Series combines the Management features of Synology's Surveillnace Station, with Advanced Analytics, designed to fit deployments of all sizes.
Intelligent Analytics - Included in DVA NVRs to strengthen on-premises security, offering deep learning algorithms and detection profiles
  • People and Vehicle detection - Trigger immediate or threshold-based alerts, using idle times, within defined zones (for vehicles or people)​
  • License Plate Recognition - Identify license plates and set up accompanying triggers (using allow/blocklists)​
  • Intrusion Detection - Set up bi-directional or one-way borders, so alerts can be issued when a trespassing vehicle or person is detected.​
  • People Counting, Congestion Alerts, and, Visitor Trends - Gauge occupancy levels in a defined space, with the counting of people leaving/entering the area. Automatic alerts can also be used to avoid congestion, once an area reaches its capacity.​
  • Personnel Detection - Equipped with the fast identification and authentication of individuals, through the use of face recognition.​
Users can choose between the more compact design of the DVA1622, or the larger storage of the DVA3221, the key features of which are both listed below.
The DVA1622, with 2 Drive bays, and support for 16 IP camera channels, is an All-in-one solution, ideal for small-scale installations (perfect for shops, small businesses, or home users)​
  • Intel Celeron J4125
  • 6GB DDR4 non-ECC System Memory
  • 1080p 60Hz
The DVA3221, with 4 Drive bays (max. 14 with Expansion units), and support for 32 IP camera channels, is a scalable surveillance platform, built for larger scale installations, that offers users impressive threat management and business analytics.​
  • Intel Atom C3538​
  • 8GB DDR4 non-ECC System Memory​
  • Drive Type - 3.5" SATA HDD, 2.5" SATA HDD, 2.5" SATA SSD​
  • 1080p 60Hz​
  • HDMI x 1 Video Output​
  • 3 Year Warranty (Extendable to 5 year coverage)​
The DVA Series NVRs also come equipped with the use of Dynamic Maps, allowing for improved situational awareness, and to help users to determine camera/event locations, and provide instant access to video feeds for more efficient site monitoring. This also includes the features listed below:
  • Multi-Location Alerts - Preview triggered events directly on the map with automatic zoom features to bring the most important views into focus.
  • Multi-floor Layouts - Group floor plans together for a clearer understanding of where cameras are located, and where events are set to occur.
  • Online Map Integration - Directly overlay your cameras and building layouts onto Google Maps or OpenStreetMap for better situational awareness, even across multiple, or larger sites.
VisualStation
VS360HD
Synology's VisualStation offers a PC-less, live view and playback solution, for your surveillance footage, with the ability to work in mobile environments.
Designed to work as a companion system, the VisualStation also offers an ultra-compact design, and features Synology SurveillanceStation live view and management tools. It is a perfect alternative for a Video recording solution, for users facing budget or space constraints.
  • Dual Screen Display (users are able to switch between Mirrored and Extended desktop modes)
  • HDMI/VGA Dual Full HD Output
  • Fan-less Design
  • 3 Year Warranty
How It Works:
Plug in an Ethernet cable, connect the VisualStation to a LCD-monitor or TV, log into the Synology SurveillanceStation - and its all set up, for quick and easy use.
The VS360HD is also equipped for use in harsh and mobile environments. With a design free from mechanical moving parts, the VisualStation is more resistant against vibration and hardware failure, than other Network Video Recording solutions.
Its design also features a solid outer case, built to keep it running in industrial temperature ranges (-20°c ~ 50°c)
This is what makes the Synology VisualStation both a cost effective, and reliable system, for any user.
For more information about these products, please visit the attatched links for our Use-IP Product Pages​
Status
