Thoughts on these 20x optical zoom cameras?
P6RAF
Are you going to use them standalone or connected to an NVR - depending on the NVR some will support more functions than others.
I have Hikvision NVR's where the Jidetech will only work on Onvif - and other non Hikvision cameras the same - but if your NVR has certain functionalities you might be better off getting something that connects more easily and allows a few of the smart features to work (like intrusion detection and line crossing).
Do you 'need' an 8mp camera? If you're connecting to an NVR - check that it can take it at full stream/resolution based on what you've already got connected.
