iVMS-4200 Upgrade from iVMS-4200 v2.7.1.4
looker44
total newbie here. Client is running iVMS-4200 v2.7.1.4, needs new workstation. Can i install latest version v3.7.1.5 and load the config export from the old system and all work ok
Well, that should work :)
It's hard for us to know with any degree of certainty whether it actually will for any version to version upgrade.
It certainly shouldn't make matters worse i.e. if it fails you'll have some manual tweaks to finish-off.
Or, worst case, you'd have to default and start from scratch with a manual re-configuration.
Hi, i think you will have all new installation. From my case, i have v2 and v3 installed on laptop (just differetn path of installation).
So i don't think you will have your data on new v3 IVMS.
