Use IVMS as NVR
dturtill
I have a request to install 20 Pano VU cameras each with 4 channels obviously this is 80 channels in total, I know the NVR's are not fit for this many channels but didn't know if I could use a dedicated server running IVMS as my NVR and have these installed on there instead
thanks
It's a pretty challenging spec. (that many complex cameras/channels).
I would certainly prefer to use the camera manufacturer's own software.
I would run it past Hikvision Tech Support.
They may recommend HikCentral software.
But also, should be able to give you some guidance on hardware configuration; CPU(s), RAM, etc.
