I also have another finding am trying to understand. I have heard of a reverse POE Switch which doesnt rely on your own power as an ISP to power up the switch, rather you use power from the clients side to power up your switch. So even if you as an ISP when you dont have power on your side the devices will still power on and continue to work as normal. Now on this reverse POE switch theres a DC output which can power up an extenal device through normal DC pin. So my querry is, I have an extenral router which uses a pin to power up, the only problem is that this router needs at least 48V to be powered up, so is there any way to boost or step up the 12V provided by the Reverse POE switch to 48V to help me power up the external Router? And if Yes, whats the best Step up device should I use? Kindly any assistance to this is highly appreciated.
