cctvfan
- 10
- 1
Hi Use-IP Forum
Nice to here, seems a very friendly bunch!
Looking at some CCTV cameras, specifically the Hikvision ColorVu.
Leaning toward the 8MP Turrets, specifically the DS-2CD2387G2-LU. I am concerned at their size however, particularly as some (poistion 2, 3 and maybe 4) will be at ground floor level (not at 1st floor, soffits)
My house has an unusual layout, there is a pitched single storey part of the house at the front. That makes 1st floor soffit mounting a bit useless due to blind spots that would occur as a result. However, I have thought of the following.
See images at:
Rear (Position 1 + 2) @ https://ibb.co/xs6pjxn
Front (Position 3, 4 + 5) @ https://ibb.co/Nm0XxHX
How can I get the best visibility on the property? Any recommendations?
See images at:
- Position 1 = Looking to the patio and double doors there.
- Position 2 = Looking to the convservatory and double doors on conservatory.
- Position 3 = Looking across the driveway and grass (at the front on the soffit, not flush against the black door).
- Position 4 = Looking over the driveway / cars / side gate (struggling with position along roof tile edge / angles / what will be most useful here)
- Position 5 = Looking backward down the side of the house (cannot show angle, no photo down that side)
- I keep hearing "4MP is good enough and more pixels doesn't mean better image." I understand that, but I also believe the sensor in ColorVu 8MP is very large, so works just fine. Is this the case? The more detail the better, and I believe we can achieve this with a sufficient sensor size. I want to future proof what I can.
- The 8MP Turret ColorVu are rather large units. Do we think they are too large? Am I better with a bullet or even a vandal-proof dome in certain positions (I am thinking position 2 and 3, maybe even 4)? The white LED appeals to me though, giving a bit of light as well as the ColorVu image. I understand there is no LED on the domes? Open to suggestions for on what specific cams should go where.
- I have rather small soffits that do not stick out a great deal. Are the rain/sun shades worthwhile as I've got small soffits? Or is that just asking for spiders / webs to take shelter inside? Or should the cameras be fine in even heavy downpour?
- How can I get the best visibility by the garage (position 4)? A very wide area and no corner points to mount cameras to. Very small soffits too. Where on the garage would you mount it? Right at the top of the apex? Facing forward or slightly toward the gate? Or focus on the cars? Open to suggestions here, this is the difficult part! The 8MP ColourVu Turrets might really stick out, be exposed and look odd.
- Recommended Doorbell camera? Hikvision too? This will give another dimension in addition to the cameras shown in the pictures.
- I've been looking at some ColorVu domes for by the front door (position 3) if the turret is too large. Welcome any views here. It is really very accessible for a tall burglar. But maybe a good thing for seeing faces.
- Is there an equivelent to DS-2CD2387G2-LU in a dome rather than turret? Same spec / sensor performance / LED / Microphone?
- Planning to put the NVR and other equipment in a server cabinet in the loft. Any issues you guys anticipate? It gets hot up there, measured 39.9 c in the summer.
- Are the placement heights and positions of cameras about right? Welcome any advice.
- I am looking at the DS-7608NI-I2-8P (based on what I have read on this forum RE: 4K, and the K NVR not being strong enough). Is this a good idea? 6TB OK?
- The event recording that comes with Acusense appeals too.
- Any other suggestions? Additional cameras for better coverage?
