Which Dome Hik Camera
2155 is a new model, from their EasyIP 3.0 range
2152 is probably an older model, I've never seen it in the UK - traditional IR LEDs (not EXIR), not Wide Dynamic range, and no h.265+ latest CODEC.
But probably more than adequate for your drive if you have one.
Yes, it's a 5MP vandal-resistant dome camera - it should suit your application well
Assuming you are mounting low, and therefore need VR
And your car is relatively close (hence you selecting the wide view 2.8mm lens)
hi Phil
oh, none of those apply its going to be mounted up in the eaves hopefully the below link should work, to the right of the upstairs window above the front door.
Imgur: The most awesome images on the Internet
zx7ft
zx7ft
