WiFi and battery doorbell choice with Hik Connect
R898989
Hii, I'm looking for a Doorbell which will work with an existing hikvision K series NVR.
The doorbell needs to ideally be WiFi and battery due to difficulties cabling.
Needs to at least stream to the NVR so it can be viewed on hik connect app alongside other cameras.
Needs to function as a doorbell best case a chime but can be an app notification. This part doesn't need to use hik connect app.
EZVIZ have some WiFi/battery models but all seems to suggest no onvif support, so couldn't be added to hik connect. Hikvison ones all seem to be hard wired.
Any suggestions?
I didnt see any ezviz like solution in hikvision.
Also even if its possible to add ezviz doorbell to NVR, do you think battery would last? It would have to stream 24/7. I believe battery would die pretty soon, and you would end up charging/replacing battery pretty often to the point it would be cheaper to lay cables.
Yes good point on.the battery usage, probably why none exist ! Looks like my my best option maybe finding a wiring method . Any suggestions on wired WiFi doorbell model, hikvision, that has the record to NVR functionality ,?
