Bullet camera mount won't tighten enough, is there any known fix?
LoinKing
I have a few year old hikvision bullet cameras. When new, I was able to tighten the locking nut and the camera would lock in place firmly.
Now, it doesn't matter how much I tighten the locking nut, I can easily move the camera by hand.
Is there a way to fix this?
Hi @LoinKing
Do you know the exact model number of the bullet camera you have?
The design of the Hikvision bullet cameras does change a bit between different models.
Is it specifically the hand-tightened nut against the mounting plate that is failing?
Does it come loose?
Or just not do its job any more even though it is tight?
Does it come loose?
Yes, the hand-tightened nut. Its not doing its job, even after fully tightened.
