DS-2CD7A26G0/P-IZS crashed after update to Firmware_V5.6.11_210129 from V5.6.10 build 220924
IVAN G
I have just bought this and updated when I got it and all of a sudden it crashed and constantly reboots it stays live for about 20-30 seconds then crashes and all I can do is get into maintenance and there is nothing in it then crashes again. Any help would be grateful
Solution
Do you have a separate POE switch that you can connect the camera to?
If you do, connect the ANPR camera to that, as the Batch Configuration tool will then be able to find it for you to try and load the original firmware back on to it.
Thanks,
I think you may have installed the wrong firmware, unfortunately, the ANPR models and which firmware versions they use are much more complicated than other standard Hikvision cameras.
The V5.6.10_Build 220924 you were originally on was first released in September 2022 (build number is the release date in the Chinese format [YY/MM/DD]) and the V5.6.11 firmware you updated to was older having been released in January 2021.
There is different firmware for the ANPR cameras depending on the region the camera is from and when you look at the UK Download Portal you will see that V5.6.10_220924 is the latest firmware available, and if you look at the EU Download Portal you will see the V5.6.11 firmware but you also see that the previous V5.6.10 firmware is a completely different build number (191023) to the UK firmware.
Maybe try hard resetting the camera to see if it will stabilise long enough for you to re-install the V5.6.10 firmware
Try the Batch Configuration Tool to do the upgrade (add your camera to the device list, and select it, and then use the Upgrade button at the top of the tool).
It's normally quicker than logging into the camera and doing it - make sure you're uploading the 'digicap.dav' file too.
Do you mean it is not showing on the online devices list at the bottom?
You'll probably need to click the arrow button shown below to pull this up:
If not, make sure you are not running any VPN software, any firewall and antivirus software is not blocking Batch Config from running properly, and that you are using a PC connected to the same local network as the camera.
Hardwiring the PC to the router via ethernet cable rather than using Wi-Fi might help too.
I have everything going through a NVR and the crash time has sped up
Solution
Got it working thank you I connected it up to a POE switch and fiddled about and finally got it working thank you for you for all your help it was very much appreciated.
No problem, thanks for letting us know. Did loading the old firmware back on via the Batch Config tool fix it?
yes returned it back to the correct system it is now just running on a window sill doing a long test before replacing my old system thanks.
