All the connections looks to be working after setup except when the call comes from the outdoor unit the unlock function on the indoor unit seems to send the signal to the outdoor unit as I can hear the relay click in the outdoor unit. I have connected the door lock to the power supply and to the indoor unit for better security. I have put the relay icon on the desktop of the indoor unit and if activated it unlocks the door so this would mean I have connected the cables correctly.
The problem should be in the configuration I think as I could not find any info how to set up this kind of wiring. I have tried to enable the relay settings in the Calling Linkage but it did not work (I was not sure what I was doing it was just test and trial). After some time in the config panels of both units I see that they can be setup as main/sub/extension for the indoor unit and villa door station/doorphone for outdoor station. This gives too many possible settings and thus I am asking here. I assume that setting the outdoor unit to doorphone and the indoor unit to be Main unit would do the trick but would then the unlocking on the outdoor unit still be possible? Another setting I see fit is setting the indoor unit as sub door station - is this it?
Hope I wrote in understandable way
