Hello, I have found myself back with the good old fashioned traditional problem of the WebServiceComponents plugin not working properly.
My system has a DS-7716NI-E4/16P NVR which is **FULLY UPDATED** to the most recent firmware, a DS-6704HUHI-K which as far as I'm aware there are no firmware updates available for, then the cameras are DS-2CD2347G2H-LISU/SL, DS-2CD2555FWD-I, DS-2DE2A404IW-DE3, DS-2DE4220IW-DE.
Up until about 2 weeks ago I didn't have any problems (a term I use loosely, because the webpage video feed for the 2A404IW mini-ptz for a while would only work if the page was viewed in IE Mode within Edge, then out of nowhere it suddenly stopped working and now only works if the page is NOT viewed in IE Mode.... because that's obviously what's going to happen, a complete flip around for no reason) - but now I have this strange split when it comes to trying to view either video playback or the live feed on the webpage UI, which includes trying to adjust settings such as altering the intrusion zone area for example:-
I don't even get the "live view failed" message anymore, the page just sits there with a blank box where the plugin should be.
I genuinely cannot understand why this is such a problem. HTML5 video was introduced to the internet approximately an entire ice age ago, yet Hikvision still insists on using an antiquidated plugin that clearly does not work properly. Chrome does not support this plugin, Firefox does not support this plugin, and now it looks like Edge is half-in and half-out with it.....
.... so is there an actual working solution that I have not yet tried?
There is a bit of footage from one camera that I'd like to download to my PC before the footage is wiped in just under 3 weeks' time, but obviously I can't do it directly because the NVR is one of the devices which the plugin isn't working for (and all my USB sticks are currently full with data being used for other applications right now)
- DS-2CD2347G2H-LISU/SL, DS-2CD2555FWD-I, DS-2DE2A404IW-DE3
- these work fine in *normal* Edge browser without IE mode, but they do NOT work in IE Mode... the DS-2DE mini-PTZ used to work in IE mode. - DS7716NI-E4 NVR, DS-2DE4220IW-DE ptz, DS-6704HUHI-K
- previously these *used to work* in "IE Mode" within Edge browser, but now they do not and they do not work in normal Edge browser or any other browser
