I bought my HikVision system from use-ip about 1 year ago and it generally works ok, however I have a few niggles which suggest it’s not quite set up correctly. I set up via ‘plug and play’ and I use the NVR as a virtual host for the cameras.
My issues are as follows: -
NVR
DS-7608NI-I2 8-channel
Cameras (set to H.265 or H.265+)
3 x DS-2CD2386G2-IU
2 x DS-2CD2386G2-ISU/SL
1 x DS-2CD2545FWD-IWS (This one performs/streams the best, presumably because of the lower quality)
Apologies for the long post, but I am not sure if these are all related. Happy to repost separately if required.
I have scanned through the ‘how to’ guides and other posts, but can’t see anything which matches my exact problems.
Any help will be very much appreciated!
Thanks, Simon.
- Every few months, my whole system will go offline and it only returns once I reboot.
- When I access Hik-Connect via my iPhone 12, it often shows ‘Network is unstable. Connecting again…’ It also sometimes plays one camera (out of 6) and shows a ‘play’ button for the rest. When I select individual cameras, it can take up to 10 seconds to show the live view or it times out and shows the above message.
- Occasionally, the NVR and cameras all go offline together (usually after multiple attempts to view remotely after timing out – re point 2 above) however the system returns back to normal on its own after about 5 minutes.
- I once had an issue where the system appeared offline via two different iPhones, however when I then tried to access via my iPad, it showed ‘No more connections allowed’. Again, a reboot resolved the issue.
NVR
3 x DS-2CD2386G2-IU
Thanks, Simon.
