Motion Detection Menu on Hiwatch ip camera?
Trying to set up the motion detection settings on my x2 hiwatch cameras
can anyone tell me what these settings do on the configuration menu
thank you
Hi @warrendanielsmith
They're explained nicely in this post:
Be careful with the percentage setting.
Sensitivity: Range [1-100]. The value of the sensitivity defines the size of the
object which can trigger the alarm. When the sensitivity is high, a very small
object can trigger the alarm.
Percentage: Range [1-100]. Percentage defines the ratio of the in-region part of
the object which can trigger the alarm. For example, if the percentage is set as
50%, when the object enters the region and occupies half of the whole region, the
alarm is triggered.
I suggest lowering the percentage to 0% for testing, you can always fine-tune later.
Scheduled settings at OFF should trigger 24/7 (mine does).
