Minor niggle, NVR playback on higher mega pixel cameras jumps at what appears to be the pre-record buffer point and isn't as smooth as it could be.
However on iVMS playback directly from the NVR on a wired network is very smooth.
I've since got 4.60.005 working well from the NVR and iVMS.Didn't notice you mentioned this... I loaded V4.60.005 again and playback on iVMS-4200 is good.
The critical thing seems to be matching the main stream event video settings to the sub stream settings in video frame rate and i-frames.
I think you meant...
The critical thing seems to be matching the main stream event video settings to the main stream continuous settings in video frame rate and i-frames.
