Exactly when/where did you see this error message appear?
Did this happen the first time you tried to view your device via the app or has the device been working on the app for a while and just recently thrown up this error?
I see a few posts about HikConnect recently. I'm having similar playback issues where the app/platform will not connect to my i series NVR, or will do so intermittently for one or two cameras, When I select a channel it will either keep trying to load and eventually come back with "Connecting failed", or it will load one frame and freeze.
I thought this might be due to my upgrading to latest firmware for one NVR, but the same is happing on my second system which has not been upgraded.
It has always done it and not only on the app, also randomly on the app and NVR as well. Usually on the line crossing notifications, not on the motion notifications
I still get it - it feels like there's enough of an event to trigger an alert - but not enough movement to record any images with motion detection. So the event gets sent, and then when it tries to load the video history there's nothing there to load. So the event is more sensitive than the motion recording if that makes sense.
