Recommendation for a trailcam for my hik nvr
CHris S
Hiya I have a 7604 for home use but I want to watch a nature trail about 40m away ... is there any POE camera in the range I can use as a trail cam hooked to the NVR
Are you planning to directly wire this trail cam to the NVR using a PoE network connection?
If so we would recommend the 2545 4MP Mini Dome as that has a sorter 10m IR range for covering smaller areas and is vandal-resistant which is useful if the camera is going to be mounted at a lower height, if the trail is long and you want to cover longer than 10m then we would recommend the 2345 4MP Turret.
Thanks for responding.
A) Yes, directly wired.
B) Theyre turrets not trail cams you're recommending there or am I missing something ?
The 2345 is a turret camera, those options are the only thing we could offer as trail cameras. Trail Cameras are a specialist thing and I don't think you will find any that will connect to your network or record to an NVR.
Are you wanting to mount the camera 40m away from what you are viewing or is the cameras being mounted 40m away from the NVR?
