After updating to 4.00+ FW, and updating cameras, I have noticed there are motion setting options on the cam IP page that there isn't on the NVR e.g "Expert" Motion settings which allows you to customise a box area with sensitivity and percentage.
My questions
1)Do the settings made on the cam IP web portal trump the settings on NVR web portal?
2)Should I be setting up motion /events on each cam IP web portal separately or NVR web portal?
3)If I should be setting up motion/events on the cam IP webpage, should I disable the motion/event settings on NVR or leave them enabled and the same as the IP cam settings?
4)If "Expert" motion settings are use, is the "basic" chequered box rule ignored?
My questions
