Hi guys,
I thought of asking in this thread for a dual IME 8003 outdoor station / dual keypad / dual card reader question:
Main door station at the property gate: 192.168.1.100
DS-KD8003-IME1(B) (newer model, it comes with web interface)
DS-KD-KP Keypad module
KD-M Card Reader module
Intercom Page:
Door Station number: 0
Session Settings: Main Station IP 192.168.1.101
Password Settings: Here I setup keypad access passwords, which work
User Page: here I setup users' card access, separately for each outdoor unit
Device Management page:
Indoor Station 192.168.1.101 Floor 1 Room No. 1 No. --
Sub Door Station 192.168.1.120 Floor 1 Room No. -- No. 1
Synchronize Button: Disabled synchronize
Sub door station at the house door: 192.168.1.120
DS-KD8003-IME1(B)
Intercom Page:
Door Station number: 1
Session Settings: Main Door Station IP: 192.168.1.100, Main Station IP 192.168.1.101
Password Settings page is not visible; same passwords as main outdoor station open both doors
Device Management page is not visible.
Main indoor station:192.168.1.101
DS-KH8350WTE (managed by iVMS4200)
Network-Group Network Settings: Main Station IP Address: 192.168.1.101, (Main) Door Station IP 192.168.1.100
Three more DS-KH8350WTE sub indoor stations (DHCP IP's, they all work and call each other by pointing at the main indoor station)
Of course all units have the latest firmware and all sub modules have their unique serial address.
Almost everything works as desired:
- when you call from either outdoor station, all indoor stations ring, show related video, allow to talk and open related door
- Hikconnect setup for the main indoor station in the phone rings as well, show specific video, allow to talk and open specific door
- all indoor stations can call each other
- from the indoor stations Live View, you can select either of the two camera views outside
- card access control works from both outdoor stations, and this is important, is configured separately: some card are enabled to open both gates (owners), others are enabled to open only the main outdoor station (gardeners, access to garden only)
I am only left with this problem: the password access via keypad is shared and can only be configured from the main outdoor station, and applies to both outdoor stations. The Password settings page is not visible in the sub outdoor unit.
From the sub outdoor station, the "Device Management" page and the "Password Settings" under Intercom disappeared when I set it up the outdoor stations the way I described above. So once you have a pin code, you can always open both door which is no good for gardeners that should not be able to enter the house.
Is there a way to keep the keypad password separate, like the RF cards? So that some pins open only the main outdoor station (property gate for gardeners that should not access the house), and other pins open both the property gate and the house?
Thank you all for sharing your knowledge!
Nick
