Hi thanks for your respond,,, but I registered but I did find next firmw which will be compatibility with this model
I tried here: 09-Firmware / IP / IPC
Do yoy have better web for this model?
thans
If you look at the document titled 'IPC Platform.pdf' at the top of that IPC folder you will see that the table in that document states your model uses the G0 firmware so the latest firmware for your camera would be IPC_G0_EN_STD_5.5.80_180911.zip
