Yeskamo Security NVR System Stopped Streaming over PC LAN?
pdoth
I have been using a Yeskamo NVR security camera system for approx. 3 years viewing live streams via both a PC App and a mobile APP, without any issues.
A few days ago I selected the APP, EsseCloud v3.0.3 on my PC which is connected via Local Lan connection to view the stream(s). The APP started as usual showing 4 camera channels however, even after waiting 3min none of the streams came through. All 4 channels simply showed "Loading" in the top left corner until the message - "Channel (x) Failed" appeared.
For the last few days I have tried:
> Uninstalling/re-installing the EsseCloud APP
> Disconnecting/re-connecting all cameras.
> Looked through every option on my router.
> Checked all settings I could find concerned with Lan security/operation
> Checked all security/anti-virus software
> Replaced Cat wires/HDMI cable
> Factory Re-set/re-booted Yeskamo NVR unit
The strange thing is that all streams are still working as normal on my mobile phone via the APP. I 'assume' this means that the data signal from the NVR is going through to my network for access to/from the web as it is being picked up by the APP?
I have now reached the stage of not knowing what the hell to do or try next???
It 'would appear' that the issue 'could' be with the connection between the NVR/modem and my PC but, I have looked at everything I can think of.
Does anybody have any other suggestions or, is having/had the same issue?
Any help would be most appreciated.
[Windows 11 Pro]
pdoth
Do you have any Anti-Virus / Firewall software on your PC?
Maybe try again with the 'Shields Down'.
