rickwookie
- Messages
- 48
- Points
- 8
I have been told:
1. The previously identified bugs in version 5.0 have been addressed.
Can anyone comment on this, specifically is streaming via Hit-Connect now smooth again?
I have been told:
Live streaming is fine for me, but playback is still painfully slowCan anyone comment on this, specifically is streaming via Hit-Connect now smooth again?
So, not fixed then. That's a shame because I was hoping that V5 would fix 3rd-party RTSP/Onvif streams not working for me on V4.63.020, but it looks as though I should stick with V4 since at least the basics work on that!Live streaming is fine for me, but playback is still painfully slow
Using an EZVIZ DB1 Pro 5MP on an M2 with 5.02 firmware, it's working fine.
Yes @johnfitzy. Ezviz confuse admin password with verification code. Once adding an admin password then this is also the new verification code. I had exactly the same problem with Ezviz H3 3K. Also sometimes was recognized at once as plug n play, some others manually with Hikvision protocol.did you change the password from the default (verification code) or do anything else to get it working?
I’m using the 6 character code from the barcode as the password.Hi @kraven ... I have one of the EZVIZ DB1 Pro doorbells also but since V5.0 arrived I cannot get it to connect with HIKVISION protocol... It tells me I have the wrong password, but that same password works for RTSP... so I use HIKVISION_RTSP... did you change the password from the default (verification code) or do anything else to get it working?
Great. I'll load it on mine now and see if the other issues are still present but I think that was the worst bugthat little .005 seems to have done the trick... buttery smooth playback in Hik-connect!![]()
Keen to try again though, could I ask if any uses full screen alarm notification and if that works, I swear It didn't on the first versions of 5?
Also, when in full screen view of your grid of channels, hovering over a channel brings up a menu barf of items which never seemed to disappear - has that been fixed too?
Everyone else playback fixed on hik connect?
I'm seeing playback as smooth for anything recorded both before and after the latest update. What is still problematic is the loading of the timeline. I've just checked now; the first attempt had the video playing within a couple of seconds, but the loading circle spinning for 20 seconds before the timeline appeared. Another attempt took longer still. That's while my phone is connected to my home network. Trying the same on another recorder that supports the feature (a DS-7608NI-K2/8P) took just two seconds.Weird, im definitely on the latest of both but still some minor issues when going back a few days etc. will keep an eye
